leak down results
139,000 miles, stock motor, I didn't think to ask an explanation so Im not 100% sure what he means by rings, but Ill just write it down as it was written for me:
1 - 1% rings
2 - 8% ex valves
3 - 5% ex valves
4 - 0%
1 - 1% rings
2 - 8% ex valves
3 - 5% ex valves
4 - 0%
Depends on what level of "freshening" up you need. Heavy oil usage is the typical first signs of engine needing a rebuild, the trick as with the comp and leak down testing, is to determine where your using the oil, whether its bottom end ie: piston and rings, or top end, valve guides and seals. Right now your numbers aren’t bad and if your oil usage is still reasonable then you don’t need to do anything. As you put more and more miles on the car, those % by nature will increase and the results will be lower compression/power and more oil usage. There is nothing you can do to prevent this inevitable, only prolong it by providing the motor with clean filtration and good oil that’s always topped off with good change intervals. It appears by your mileage and leak down numbers that your doing pretty good, so keep it up and don’t worry about it.
Originally Posted by omgitsoop' timestamp='1364414986' post='22432805
REVIVED! Just curious, at what point do I look into refreshing the motor, and what all does that entail? I'm at 148k now.
Requiem
Aug 17, 2010 12:11 AM
