leaking fluid need help!
Old Jan 21, 2011 | 11:57 AM
FUSIONX8887's Avatar
Default leaking fluid need help!
i just recently noticed that for about two days i have been leaking fluid in my driveway.
after lifting up the car i noticed it was leaking from between the motor and the transmission. its a consistent amount all the time.
can i have some of your guys imput as to what the problem could be
Old Jan 21, 2011 | 01:05 PM
nin10dough's Avatar
Simple.
Either Main shaft seal or engine seal. If it's tranny fluid then its the shaft seal, if its engine oil its the engine seal.
I replaced my main shaft seal, if you need I have a new engine seal from Honda I didn't need to install.
Old Jan 21, 2011 | 02:02 PM
flyingtoaster's Avatar
Probably the engine seal (rear main). The clutch shop told me in advance to pay for the seal as preventative maintenance before they even went to work. Sure enough, it was slowly seeping oil, but not enough to leak.
Old Jan 21, 2011 | 03:01 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
It can also be the oil gallery plug on the back of the block. It uses an aluminium oring, and can be distorted from the factory. It has a large Allen key hole, and os behind the flywheel. Take a peek while its apart.
Sylvan
Mar 22, 2016 04:19 PM
dogzilla
May 30, 2013 11:39 AM
shiesty
Aug 26, 2006 01:55 PM
papa5murf
Apr 2, 2005 09:11 AM
