Leaking - Water in Boot - Trunk (pics+fix)
Originally Posted by Random1,Feb 3 2008, 10:37 PM
This is a little bit of thread jacking, but related...
I'm not sure what to do with the top on the car. I removed the sink and cleaned it and the drain pipe when the top was off. Access looks difficult with the top installed. With the top down maybe some water could be added to the sink on each side and then sucked out with a shop vac. A small pipe may need to be adapted to the shop vac get down in there. Liquid Plummer? Check the drainage before and after your work to see if there is an improvement.
There are some additional photos that may help at the link below. Good luck.
http://www.pbase.com/rsrock/top_replace
Thanks for the suggestion on checking for clogged drains here, I wasn't even sure where to start until I saw your pictures.
The saga continues, even after cleaning the sinks I'm still getting water in. I'm thinking the drains are still partially blocked even though the sink is clean. Going to give it another shot, really hope I don't need to rip this stuff out to clear it.
The drain tubes go out the bottom somewhere. It may be worth a try to blow compressed air up into them from the bottom provided you can get to them. Maybe with some water in the sinks and blowing up from the bottom it will help?
Just did this fix and have one additional comment: Don't squeeze the f'n tube of black silicon from the middle. That stuff is so thick that the back of the tube will explode!
I spent an hour in the tub scrubbing my hands THEN had to spend 20 minutes cleaning the black residue from the tub FTMFL!!!
Rather than use Draino, I figured a snake would be a better bet, and I decided to go spelunking under the car for the drain exits. With the back end raised on jack stands, I poured water on the top to see where it exited. Nothing at first, then a drip...drip...drip just in front of the rear tire. I removed the tires, and traced the drips up to the drain exit along the front of the fender. The "snake tool" I used was just a claw pick-up tool that has a flexible shaft.
Remember, this is the right rear...
Looking across the suspension towards the front of the wheel well
A little closer, you can see the little rubber tube - that's the drain exit.
And here it is with my "snake" tool in place.
What I found easiest was to put the snake in the tube, pour a few cups of water on the top, then move the snake in and out to dislodge the debris as the water poured through. I got several clumps of black dirt out of each side (no doubt decomposed leaves and debris).
Now that the drains are clear, I can pour a bucket of water on the top, and have it all exit out the bottom in a matter of seconds.
No water in the trunk!
this is such a helpful thread! i thought the vent was the source of water, but i STILL get water in the trunk, and it must be these drain tubes...
i was going crazy because I'd like to have my liner back in , but it's been out for years because of all the rain...
pouring water on the top doesn't really help because i guess the tubes are working but just slowly.
i will try the snaking method, it looks like a good fix.
thanks everybody!
thanks everybody!
Just to add to this. If you seal up the boot vent with draught excluder or something you may not stop the leak. Mine was leaking through one of the white fixings. A while after I sprayed water over the car it trickles along the metal at the bottom of the boot/trunk lid where the rear bumper attaches. The left edge of this is directly above the left fixing of the vent. It runs down the outside and through the white fixing.
So seal that up too!
