Locking Cams into Vtec
Old Oct 9, 2017 | 08:27 AM
  #21
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I have driven S2000s with locked assemblies/killer cams.
They literally feel like the tailpipe is stuffed with bananas. The car was slow and throttle response was horrible.
Old Oct 9, 2017 | 04:50 PM
  #22
DefSport's Avatar
Originally Posted by s2000sccaracer
I have thought about the reduced oil flow to the cams, with the vtec locked. This is one reason I am asking if anyone has had any success with locking vtec, before I try it. There are Youtube videos of someone that locked Vtec in an S, but they only had the car idling. No follow up if the engine stayed together.
If you can adjust VTEC to any RPM you like, I still don't see what the benefit of locking the cams onto the VTEC lobe at all times is going to gain you.
Seems like any potential negative, even if it's remote, isn't worth it given it's only taking some performance away (however unlikely it is you'll use low RPM torque), and there are zero benefits to it.
Old Oct 9, 2017 | 08:29 PM
  #23
s2000Junky's Avatar
The common and sensible way to go about this is to force vtec to come on through the ECU, whether you piggy back it with a simple AFC NEO, E-manage or go full blown EMS, either way it makes no sense to mechanically lock the cams in place and lose performance all the way up until the engine breathing can make use of the cam profile which is generally no lower then 3500rpms.
The engine makes full oil pressure as low as about 3k rpms.
FormulaRedline
May 6, 2013 11:36 AM
Huntsmcgee
Nov 11, 2009 07:27 PM
1a-race
Jul 3, 2002 05:38 AM
Triple-H
Apr 19, 2002 09:11 AM
dbkelly
Feb 23, 2001 09:29 AM
