loud slapping/tapping from engine..
Old Aug 21, 2007 | 08:23 PM
ciscokid209's Avatar
Default loud slapping/tapping from engine..
hey friends
here we go i have a 2000 s2k with 64k miles,i was testing out my 4.77 gears and wanted to see what my top speed would be with new gears any ways i was at around 8k rpm in 6th gear when car just felt like it ran out of gear so i put it in neutral and come to a stop and make a u turn thats when i start hearing loud slapping/tapping sound so i just turn off car and get it towed home.I pulled oil pan and found no shavings of metal cheaked rod bearings and they are all good now im worrried its the crank bearing but dont know how to cheak that one,was also going to change timing chain tensioner,also i removed valve cover and looked for cracked retainers and everything looks fine.any other places i should be looking?but i really need help cheaking the crank bearing..
thanks everyone!!!
Old Aug 21, 2007 | 08:28 PM
antonio88x's Avatar
Could you describe more by what you mean "car just felt like it ran out of gear". If you just installed the 4.77s then I think you should look there first. But you said the sound was comming from the engine, so I'm a little confused.
Old Aug 21, 2007 | 08:44 PM
its nothing to do with the gears it was just i was at a high speed then car just lost power and when i stopped thats when engine started making loud tapping noise..
Old Aug 21, 2007 | 08:46 PM
RACER's Avatar
Were you low on oil?
Old Aug 21, 2007 | 08:48 PM
RACER's Avatar
Old Aug 21, 2007 | 08:52 PM
Originally Posted by RACER,Aug 21 2007, 08:48 PM
very helpfull
Old Aug 21, 2007 | 08:55 PM
but oil was perfect before and after this happend..
Old Aug 21, 2007 | 09:07 PM
RACER's Avatar
Slapping/tapping sounds accompanied by a sudden loss of power would suggest an expired engine
Sorry Bro
Old Aug 22, 2007 | 05:35 AM
prodriverex's Avatar
I had the same feeling on my rex a month ago. was on the track though. I hit redline while upshifting out of corner.. gosh it hold for like forever although for 1 sec..
Then by the next corner, it was tapping louder and louder..
Had it torn open and crank shaft gone and 2 conrods gone. Bearings, valve seals, gaskets, O-rings, etc.. replaced!
JoePhotographer
Nov 7, 2016 04:30 AM
Sean_2000
Feb 19, 2013 04:51 PM
hdublax625
May 16, 2010 04:23 PM
rocrfella
Aug 27, 2007 07:41 PM
ciscokid209
Aug 21, 2007 07:16 AM
