Low Compression Test Results
Old Sep 9, 2018 | 05:34 PM
tohlenforst's Avatar
Originally Posted by Chibo
I tested with the same tester as you and got similar results, it lead me down a paranoid path thinking I'd be shopping for a new motor soon. Long story short, everything is fine and the car tested at leakdown numbers below like 5% and tested normal compression numbers on a different gauge.
Well that's good to hear!
Did you use a Harbor Freight leak-down tester or did you opt to go with something a little nicer? I'm pretty sure I've got a leak(s) based on the oil on the exterior of the engine. More than anything, before I continue doing work on the car (needs a lot of body work and misc engine work) I just want to make sure the engine is healthy since that's priority #1.
Old Sep 9, 2018 | 05:36 PM
lookstoomuch's Avatar
BTW see you are using a K&N filter many people consider using an OEM filter on these to be a must. Dont want to start another engine oil or filter debate though.
No, that leak is not a source of any low compression.
Old Sep 9, 2018 | 06:35 PM
Thank you. I've used a few different oil filters: OEM, Bosch, and K&N. They all seem to work fine, I haven't found any of them to be particularly better than the other for my uses. I change my oil and filter pretty frequently and check my oil levels frequently. I just use the car as a daily driver (no track use) so as long as it doesn't cause any damage I don't mind. I only recently moved near a Honda dealership so I may switch back to OEM if the price is reasonable. For oil I've just been using Castrol GTX 10W-30, it's been great. I sometimes use the High Mileage variant if I can find it, but they both seem to do the job. I have yet to try Mobil-1 but I hear great things (outside of burning a lot of oil). Oil burning hasn't really been that much of an issue, I don't use VTEC that often and mostly just drive regularly unless I'm impatient with people being stupid on the road . For the air filter, it's the K&N filter that a lot of people on here recommend. I installed it about a year ago and it's still really clean (looks almost brand new) but I'll probably clean it again soon to be safe. Now that the car is getting to some pretty high mileage (187k and counting), I'll probably double check all the fluids since I have no idea when the last time the Transmission or Differential fluid were replaced (Clutch and Brake fluid are fine).
Old Sep 10, 2018 | 03:33 AM
Car Analogy's Avatar
FYI, a leakdown tester won't find external oil leaks. It only finds internal 'air' leaks. It only tells you where your loss of compression is coming from.
From all indications you don't really have any loss of compression (we'll know for sure once you test with a good gauge). So a leakdown test isn't going to have any worthwhile results to offer.
Old Sep 10, 2018 | 02:19 PM
HarryD's Avatar
+1 with the other guys -- I've used the HF tester and get similarly [low-but-consistent] results.
I always make the argument that consistency is all that matters, as opposed to the raw high numbers that people are chasing, but people just don't care.
Be careful with that o-ring replacement -- follow Billman250's instructions to the dot (you do NOT want to remove the bolt too much or you'll be screwed):
https://www.s2ki.com/forums/s2000-un.../#post23054279
Old Sep 10, 2018 | 06:05 PM
I see, I completely misunderstood it's purpose, thank you for the clarification. Sounds like everything should be fine with the engine so I'm going to skip the leakdown test
Old Sep 10, 2018 | 06:07 PM
That's the same thread that I saw suggesting the replacement, I'll be sure to be careful. This is my daily driver so I can only have a few days of downtime at most so I will plan accordingly just in case.
Old Sep 16, 2018 | 12:14 AM
Originally Posted by sk2_bri
Also, what altitude are you at? I live at 5700 feet and that affects the numbers greatly. When I first saw readings around 195 psi I was worried also. But that is equivalent to about 230 psi at sea level.
Where I live is between 500-1000ft. above sea level. I don't have specifics unfortunately so I can only go off a rough estimate. I think it is just the Harbor Freight branded Compression Test that is at fault, everything appears to be good as far as the engine goes.
Patrick L
Oct 18, 2017 07:51 AM
chrisaltima
Jul 31, 2017 08:47 AM
jdblood202
Aug 9, 2014 06:43 PM
SickShift
Mar 13, 2010 07:17 AM
