low miles
Old Oct 11, 2009 | 06:56 PM
Greywolf's Avatar
Default low miles
looking at a 05 s2000 with only 15k miles on it. if the oil was changed regularly, not sure about the other fluids. is there anything to worry about?
Old Oct 11, 2009 | 07:07 PM
dammitjim's Avatar
My 02 only had 12k on it when I picked it up last month. The only things I was concerned about related to the low miles were oil, brake fluid, coolant and tires. Tires are obvious (wear, dry rot) and the rest just change if there aren't any records.
Old Oct 12, 2009 | 11:52 AM
TVPincDoc's Avatar
I'd hate to tell you how many miles my '03 has, given the long hours I work and the lack of vacations...
I drive it about one day a week so the number of miles that I have on it makes your car look high-mileage.
With regular maintenance you mostly need to worry about the tires I'd say, as well as any cosmetic issues due to aging/light exposure. I guess that the issue is that you aren't the original owner so you don't know if the maintenance was done.
Old Oct 12, 2009 | 05:40 PM
spets's Avatar
Change all the fluids and check the tires and you're good. I picked up my 04 with 11k on it.
Old Oct 12, 2009 | 07:24 PM
9K-S2K's Avatar
I picked up my 01 with 7800 miles on it in Febuary of 2007. Haven't had any problems yet except for the stock S02s which performed poorly. The only thing I am concerned with is replacing my serpentine belt which I will most likely be performing soon. Good luck!
pc2000
Apr 10, 2019 05:44 AM
jyeh74
May 18, 2011 10:01 AM
josh7owens
Aug 28, 2009 04:31 AM
tomspedale
Jul 29, 2004 06:11 PM
noTor
Nov 19, 2001 02:20 PM
