MAF Cleaner
Old Jun 7, 2010 | 07:50 AM
A.VOID's Avatar
Default MAF Cleaner
I'm getting a little idle dip at stops.
I've used MAF cleaner before, as well as clean the throttle body. I read one of the FYI's that said the ECU should self-correct, but I'm wondering if I should clean the MAF too. How about cleaning the throttle body?
Old Jun 7, 2010 | 08:15 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
There is no MAF in the S2000.
A few things that can CONTRIBUTE, but not cause all, are:
-dirty air filter
-dirty IAC valve
-ecu natural learn process
-vac line pin hole leaks
-valve adjustment
If you clean the throttle body, dont spray cleaner into the engine. use a rag, dry, and gently wipe it out.
dth26
Oct 1, 2017 01:40 PM
SWFLS2K
May 9, 2011 10:22 AM
Heiachi
Jun 14, 2009 06:49 AM
s2konroids
Oct 28, 2007 10:02 AM
kitsuki
Apr 12, 2006 04:27 PM
