MAF Cleaner
I'm getting a little idle dip at stops.
I've used MAF cleaner before, as well as clean the throttle body. I read one of the FYI's that said the ECU should self-correct, but I'm wondering if I should clean the MAF too. How about cleaning the throttle body?
There is no MAF in the S2000.
A few things that can CONTRIBUTE, but not cause all, are:
-dirty air filter
-dirty IAC valve
-ecu natural learn process
-vac line pin hole leaks
-valve adjustment
If you clean the throttle body, dont spray cleaner into the engine. use a rag, dry, and gently wipe it out.
-dirty air filter
-dirty IAC valve
-valve adjustment
dth26
Oct 1, 2017 01:40 PM
