Maintenance Help
Old Jan 17, 2011 | 03:58 PM
civic si121's Avatar
Default Maintenance Help
I have my 2004 s2k for a little over a year now and I do my regular oil changes myself I do them at every 3000 miles. Couple questions I have is should I be running synthetic oil? If so what numbers? My car has about 75,000 miles in the car. I just installed my cold air, header and catback exhaust not much but it's a start. What other maintenance should I do to the s2k so it runs perfect and smooth? Some people suggested a valve adjustment etc..
Old Jan 18, 2011 | 09:42 AM
irv_usc's Avatar
what about the rest of the fluids? diff, trans, clutch, brake?
Old Jan 18, 2011 | 11:45 AM
CarbonCrew's Avatar
Generally speaking, with 3k mile oil changes, big store synthetics would have been a waste of money.
Old Jan 18, 2011 | 11:49 AM
hirev's Avatar
I also have a 04, since 10/03...i have done the oil changes for the most part myself, use Chevron (obtained at costco) 10/30 and good quality filters, either honda, K&N or fram...i change oil about every 6 months....drive about 8,000 a year with this car...and use NO oil between changes that I can detect.
I have had fluids changed by dealer at one time....i have 52,000 miles. car runs perfectly and has always.
Old Jan 18, 2011 | 02:16 PM
I wanna change all the fluids what brands and numbers should I use for tranny diff? Clutch I need to buy soon because I feel it going when on high rpm so that will get changed soon to complete clutch kit and flywheel
Old Jan 18, 2011 | 03:16 PM
CarbonCrew's Avatar
Check out the 'Oil Journals' in the sticky at the top and do some reading. You'll get a grab bag of opinions from every Brand X fanboi by asking your question.
Tranny diff? I'm guessing you mean transmission and rear differential. For that, popular choices are Honda's MTF-2 and the GM Syncromesh. For the rear differential stick with a quality lube in the 75w-90 or 75w-110 weights. 75w-110 is a bit harder to find but is suggested, by many, to be close in specs to the original fill in the S2k.
Old Jan 18, 2011 | 03:37 PM
Bryan@BerkTechnology.com's Avatar
Former Sponsor
My S2K maintenance tips:
-Use only OEM Plugs. yes they are a rip off but the "same" NGK" plug isn't really the "same"
-oil changes every 3-5K w/ OEM filters
-Diff & tranny every year. If you can do an engine oil change you should be able to complete a diff/tranny fluid change as well.
jimbo9K
Jan 5, 2012 02:02 AM
Catahoula01
South Florida
Jul 12, 2007 05:57 AM
ONEQUIKSTI
Nov 7, 2006 04:00 AM
Stolen R
Jan 17, 2006 05:27 PM
douglasr
Apr 15, 2002 03:48 AM
