Many codes all at once!
Old Feb 4, 2009 | 11:25 AM
elemental79's Avatar
Default Many codes all at once!
Not long ago my car threw a batch of codes (the only one I remember was a Barometer code). The mechanic that checked the codes said I needed to replace my Throttle Body since the TPS was not working properly. I just recently replaced it and now I have a new batch of codes...
21 VTEC spool solenoid valve
22 VTEC SOLENOID VALVE / VTEC pressure valve
23 Knock Sensor (KS) Circuit malfunction P0325
60 AIR PUMP
61 Primary Heated Oxygen Sensor Slow Response (Sensor 1) P0133
54 CKF - crank fluctuation sensor
The only thing I can think to do is replace my Knock Sensor and possibly my O2 Sensor and maybe even my Air Pump.
I did do a clutch job a little over a year ago, and I read that can potentially damage the knock sensor.
I'm hoping someone can look at this batch of codes and find a common theme, some single point of failure. I can't see all these problems occurring by chance all at once, they must be related.
Old Feb 4, 2009 | 07:08 PM
ChefJ's Avatar
You would have known immediately if you hit the knock sensor as it wouldn't have worked after the install.
What are the P- codes
Old Feb 5, 2009 | 06:04 AM
S2Kage's Avatar
^ Agreed
Old Feb 5, 2009 | 06:08 AM
I don't have the P-codes except what is listed. I got the information I do have from various sources after doing the paperclip trick. I'm glad to hear they are likely all a part of the same wiring. I'll take a look into that.
brokens2000
Mar 26, 2017 04:00 AM
will010100
Nov 3, 2016 05:18 AM
zbt1985
Sep 3, 2015 10:40 PM
IdiotCircusBoy
Apr 15, 2013 07:04 AM
Nametaek3n
Feb 4, 2009 03:05 PM
