Placement of Sensors?
Old Jan 22, 2006 | 08:44 PM
Nametaek3n's Avatar
Default Placement of Sensors?
Does anyone happen to know where the cam or crankshaft postition sensor, the (ECT)Engine coolant temperature sensor,(TPS) Throttle position sensor, Idle Air Control(IAC), VTEC solenoid or O2 sensor? Preferably all the sensors would help. any help would be great. i'm going into a the garage tomorrow at school with the car and we have to find all the sensors, including fuel injectors, map sensor, O2 sensor, and measure the resistance in them. if anyone happens to have a diagram or a link to a honda site it would be great. I know where the MAP sensor is and the O2 sensors are. really just need help finding the other before class.
thanks,
tom
Old Jan 23, 2006 | 06:43 AM
xviper's Avatar
There's a lot of sensors on this engine, so you're asking a lot.
MAP sensor - top of throttle body.
Throttle Position Sensor - side of throttle body.
VTEC solenoid - right side of engine, at the front and top edge of block.
Oil Pressure switch - below VTEC solenoid (with the rubber boot on it).
Knock sensor - left side of engine block.
Idle Air Control solenoid - left side of head (with all those "U" shaped hose going in and out of it).
Coolant Temp - back of engine, left side, near top, next to fire wall.
Top Dead Center 1 sensor - left side of head, near the back.
Top Dead Center 2 sensor - goes in vertically at the back of the head.
Primary O2 sensor - screwed into header.
Secondary O2 sensor - screwed into cat. converter.
Secondary air injection solenoid - attached to back of airbox.
Fuel recover purge valve solenoid - attached to charcoal cannister near gas tank and left rear wheel.
Fuel level sensor - in tank.
Intake air temp sensor - screwed into intake manifold on the back 1/2.
Vehicle Speed sensor (Speedometer and odometer sensor) - screwed into left side of transmission casing.
I'm sure there's more but can't think of any right now.
Old Jan 23, 2006 | 07:23 AM
Wisconsin S2k's Avatar
my head is going to explode.
Old Jan 23, 2006 | 08:33 AM
xviper's Avatar
Oh, that would be the "head explosion" sensor, which is located in some mysterious place .................................. on the head.
Old Jan 23, 2006 | 06:08 PM
Nametaek3n's Avatar
Thanks Xviper. appreciate all the info, helped alot. Tell me about my head exploding, i am attending Universal Techinical Institute, going for BMW Step program, learning engine management in 2 1/2 weeks is rough. time to go study. later guys and thanks for the help.
tom
Old Feb 4, 2009 | 03:05 PM
HGL1668's Avatar
How about the outside temperature, which is displayed on our cluster in F?
Thomas Guide
Jul 13, 2011 07:34 PM
deibit
Sep 5, 2010 07:48 AM
ScienceofSpeed
Mar 7, 2010 07:26 PM
macr88
Engine
Jan 21, 2010 11:13 AM
S 2 Fizzle
Car Talk - Non S2000
Oct 29, 2006 03:15 AM
