Mechanical O2 Simulator
Old Jun 10, 2007 | 01:28 AM
  #251
jzz30's Avatar
it most likely will. but the only real way to tell is to do it.
Old Jun 10, 2007 | 10:04 PM
  #252
Type ?'s Avatar
I tried and it didn't work I am not sure what to do now? My car has a cel on because of the o2 sensor, I replaced it, didn't help I used the anti-foulers as instructed, and I still have that damn cel.
Old Jun 12, 2007 | 10:51 AM
  #253
Silver9k's Avatar
Which O2 sensor do you have the CEL for the primary or the secondary?
This is only for people who want to replace the cat with a testpipe...not for people with bad O2 sensors. And this is only for the secondary O2 sensor.
Also, did you reset the ECU after doing this...you have to clear the CEL and see if it comes back...not expect it to go away on its own. Other then that...I really don't know. This should work on any car theoretically, since it is a mechanical fix.
Old Jun 28, 2007 | 11:08 AM
  #254
Jp_rxb13's Avatar
Do you know if this will work on a RX 8, because like the STi i have two cats, but i didn't plan on running one high flow cat just a test pipe?
Old Jul 20, 2007 | 09:51 AM
  #255
GinoGT's Avatar
With the 06+ models, it's very likely the ECU can't be fooled. Meaning the mechanical fix doesn't work. I was told this by the people at Berk, and confirmed by my own car.
The built-in fix on the Berk TP doesn't work for me, adding yet another anti-fouler doesn't work either for me. I may be stuck in an infinite loop of CEL, clear it, CEL, clear it.....etc.
It also seems to be next to impossible to find electrical O2 simulators for this car, and purely impossible to find one that actually works.
Old Jul 20, 2007 | 03:25 PM
  #256
Slows2k's Avatar
The ECG electrical 02 sim and the Comptech 02 "Terminator" (if you can find one) Both work on 00-05 cars
Old Aug 19, 2007 | 04:59 AM
  #257
Tyraid2K's Avatar
ya i just tried this on my turbo/catless car, it didn't work at all...
wtf people
Old Aug 19, 2007 | 07:03 AM
  #258
gomarlins3's Avatar
Sorry to hear it didn't work.
Old Aug 19, 2007 | 07:38 AM
  #259
Tyraid2K's Avatar
I'm going to remove it and drill it out entirely,
in other ews I found my primary sensor, it's attached about 8 inches ahead of the secondary
Old Aug 19, 2007 | 07:47 AM
  #260
gomarlins3's Avatar
I have new drill bits if it will help.
