Mechanical O2 Simulator
Old Jun 6, 2005 | 06:32 PM
  #151
ideugene's Avatar
E-manage for me. Are readiness codes saved even if the ECU is reset? Just in case I get an emissions related CEL before I do this mod or if I dont do this mod properly.
Old Jun 6, 2005 | 06:39 PM
  #152
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
NYS inspection goes like this....
There is no emmisions gas measuring from 1996 and up, only an OBDII query which checks for codes and monitors, and the CEL comanded on. So pulling the cel bulb won't help
You can fail for a visual "no cat present" but most guys will see the nice car and not even put it on the lift.
If you show up with a few incomplete monitors, you can get a ten day. but not if it fails for a CEL first.
1996-2000 can have 2 incomplete monitors, and still pass the test
2001-2003 can have 1 incomplete monitor and still pass
2004-2005 are safety only, at this time
So an 02 sim will get you through, provided the tech doesn't fail you for a no cat.
Old Jun 6, 2005 | 06:48 PM
  #153
Billman250's Avatar
Top Answer: 1
Once you reset the ECU, all your monitors will be incomplete, or "not ready". You will then need to drive the car within it's designated drive cycle, until the conditions are met to reset them. Each one has differnt needs to complete, the cat monitor will take the longest. Can go from one day to one month or more, depending on driving style. You can also get data for each rediness code, that tells you the exact conditions to drive in for a quicker readiness.
Advice...don't reset your ECU, or interrupt battery voltage, anytime nearing the time your sticker is up
Old Jul 4, 2005 | 10:49 AM
  #154
stockevokiller's Avatar
Well I have an 05' S2k with a muffler shop 3 inch exhaust connected to the stock y-pipe and some ebay mufflers. Because I'm not dropping 1k on a titanium exhaust, just yet. I did the mechanical 02 mod and it didn't work. I disconnected the battery then a week later my check engine light came back on.
I could have bought a burger for those four bucks, or some gas.
Old Jul 4, 2005 | 11:21 AM
  #155
xviper's Avatar
Pull the code. Maybe it's something else? Where did you put the O2 simulator? Did you use 2 of them stacked together?
Old Jul 10, 2005 | 03:02 PM
  #156
I did put two stacked. I put it in the bung the muffler shop welded for me, in the stock location. I don't know how to pull the code. I just ride around with the check engine on, its new so there shouldn't be any major problems.
Old Aug 12, 2005 | 12:20 AM
  #157
CwestinAP1's Avatar
Originally Posted by Costas,May 12 2005, 04:54 PM
I got my T1R exhaust and T1R testpipe a few days ago, and did this mod as well, however the O2 sim is about 3 inches from the ground now
is there some sort of non-fouler i can get that will cause it to be at more of an angle?
my car looks like this but the angle doesn't look as downward. no CEL yet. any suggestions?
Old Aug 12, 2005 | 06:49 AM
  #158
xviper's Avatar
"in the stock location" ....................... What does this mean? If it's in the "stock" location, there is already a bung with an O2 sensor in it, so how can you put another one there? So, where is it really?
You need an OBD II reader to pull the codes or you need to find someone who has one. Perhaps Autozone or PepBoys?
Just because it's new doesn't mean there can't be anything wrong. A CEL that goes unattended can be anything and maske other codes that might be there.
Old Aug 12, 2005 | 06:51 AM
  #159
xviper's Avatar
If it were my car, I'd weld on a right angle tube.
I supposes you can just leave it till you run over something that'll snag it and yank all kinds of stuff out. Then you can assess what needs to be done.
Old Aug 12, 2005 | 11:28 AM
  #160
LLOYDJ's Avatar
Something not right there!!!!
Fitted my T1R Test Pipe a few weeks back & it's HORIZONTAL
