Minimum ecu inputs for proper operation
Hey guys, I'm working on installing the F22C out of an '05 into my Datsun 510 and am trying to figure out the wiring. I would like to delete the secondary air pump and cat, change from the engine start button to a more conventional two way switch, and in general make the stock ECU and wiring work in the 510.
I will just use the stock fuel pump circuitry and cooling fan circuitry, is there anything else I need to do than plug in all the fuse boxes, connectors, and chassis grounds?
kingart
Jun 23, 2014 08:22 AM
