Mis-shift!
So I was doing about 85-86mph..it was around 2-3am in the morning so the freeway was empty and i wanted to get home asap so yes i was going at pretty decent pace. instead of going from 4th to 5th i ended up in 3rd and obviously it wasnt the right gear for the speed. the revs jumped and i obviously felt the car lurch briefly as it banged on the limiter. i clutched in and got it in the correct gear within 2 seconds or so.
i searched around here and noticed that the consensus is that 3rd gear will max out at around 75mph. i was doing about 10mph above that.
i used to drive an AP1 and was used to having that extra 1000RPM of margin. i know that i mechanically over-reved but to what extent? =\ car is 2007 ap2. car drives and idles fine..no abnormal valvetrain noise. i've heard that symptoms of a cracked retainer and damaged springs usually dont show till miles down the road.
i have about 27xxx miles on the car and i was going to take it in at 35000 miles for a valve adjustment...can retainers and springs be inspected during a valve adjustment?
-a
-a
Retainers can be inspected when you have the valves adjusted if you ask and the mechanic knows what to look for and how to look (you need a dental mirror to look at the underside).
More than likely you are fine. 85-86mph in 3rd would put you at about 8600-8700rpm...there are some AP2s that are using an AP1 ecu to rev to 9k rpm on occasion.
