Mis-shift!
Old Aug 31, 2008 | 08:11 PM
f23power's Avatar
Default Mis-shift!
So I was doing about 85-86mph..it was around 2-3am in the morning so the freeway was empty and i wanted to get home asap so yes i was going at pretty decent pace. instead of going from 4th to 5th i ended up in 3rd and obviously it wasnt the right gear for the speed. the revs jumped and i obviously felt the car lurch briefly as it banged on the limiter. i clutched in and got it in the correct gear within 2 seconds or so.
i searched around here and noticed that the consensus is that 3rd gear will max out at around 75mph. i was doing about 10mph above that.
i used to drive an AP1 and was used to having that extra 1000RPM of margin. i know that i mechanically over-reved but to what extent? =\ car is 2007 ap2. car drives and idles fine..no abnormal valvetrain noise. i've heard that symptoms of a cracked retainer and damaged springs usually dont show till miles down the road.
i have about 27xxx miles on the car and i was going to take it in at 35000 miles for a valve adjustment...can retainers and springs be inspected during a valve adjustment?
-a
Old Aug 31, 2008 | 08:23 PM
GT_NFR's Avatar
Just go ahead and do your valve adjustment now. That way you'll get your valves adjusted and make sure your retainers didn't crack.
EDIT: Sorry, YES they can be inspected.
Old Aug 31, 2008 | 08:55 PM
negcamber's Avatar
Retainers can be inspected when you have the valves adjusted if you ask and the mechanic knows what to look for and how to look (you need a dental mirror to look at the underside).
More than likely you are fine. 85-86mph in 3rd would put you at about 8600-8700rpm...there are some AP2s that are using an AP1 ecu to rev to 9k rpm on occasion.
Old Aug 31, 2008 | 09:22 PM
9kFever's Avatar
You are fine if you were at that speed. AP2 retainers are pretty strong. You felt the fuel cut?
Old Aug 31, 2008 | 10:59 PM
chairmnofthboard's Avatar
Just pop the valve cover and check your retainers. It's no big deal, I've done the same thing several times, and no cracked retainers.
EleeT007
Sep 3, 2012 08:07 AM
s2.2k
Feb 8, 2012 02:41 PM
goofball123321
Oct 13, 2011 01:38 PM
Slick2K
Jun 2, 2009 06:48 AM
AP2
Jan 6, 2007 11:42 PM
