Misshift at low RPMs
Old Aug 15, 2010 | 08:36 AM
enkrates2k's Avatar
Default Misshift at low RPMs
I was entering a turn slowing down to 40mph around 2500rpms, I downshifted from 5th to 2nd(instead of 4), there was hard pull back and the rear tires screeched. I didn't notice what was the resulting rpms at 2nd but I am pretty sure it didn't even reach redline, but can this damage the engine because of the big jump in rpm?
I drove it around for an hour afterward and everything seems fine but I am worry if there are any damages to the engine that will surface later on.
Old Aug 15, 2010 | 09:03 AM
triddle's Avatar
40 mph in 2nd gear is a good way to get onto the freeway, it doesn't blow your engine up.
Old Aug 15, 2010 | 09:06 AM
JCarp21's Avatar
yeah youre fine, just rev match the engine next time.
Old Aug 15, 2010 | 06:48 PM
climhazzard's Avatar
Shouldn't harm the engine, not too great for the clutch but I wouldn't worry about it.
Old Aug 16, 2010 | 08:06 AM
rob-2's Avatar
The stress of this will likely be felt in your diff. Your tires screeched as they were instantly slowed down. You can ruin in a diff doing this.
Motor & clutch will be fine.
Old Aug 18, 2010 | 08:18 AM
enkrates2k's Avatar
thank you guys...ease my worry a bit...i am still getting used to the short shifter.
Old Aug 18, 2010 | 12:05 PM
BuckyN8's Avatar
I have done that a couple of times before. Just when you feel the power coming up quicker than it would if you would of shifted into fourth, press the clutch back in asap.
Saltymooring
Apr 2, 2015 10:51 AM
SpinningHigh04
Jul 27, 2012 06:09 AM
damsas
Jan 27, 2006 01:31 AM
ProV1
May 16, 2005 10:24 AM
zero_to60
Jul 31, 2003 04:59 PM
