MTF and DIFF fluid
Old Mar 22, 2009 | 11:41 AM
JDMQuip's Avatar
Honda MTF and LE1605 for my diff with 4.77's. Works like a charm and I drive like a madman.
Old Mar 22, 2009 | 05:54 PM
iam7head's Avatar
MTF: make sure, it's in the ball park of 10w30 viscosity, there's TONS of MTF fluid out there with 75w90 weight(mazda, toyota, etc)
make sure you don't use anything GL5 in your trans, or the brass syncro will be gone before you know it.
recommendation: GMSM FM, pennzoil SM(rumor to be the same as GM as 1/2 price), new OEM mtf
Diff: any GL5 75w90 will do, again there's tons of single weight fluid out there, but i would stick to 75w90 weight.
Recommendation: LE, M1, Redline
personally i use OEM MTF and m1 7590 for the street, it's a pain to pay 10 buck shipping for a ten dollar bottle of oil
Old Mar 23, 2009 | 04:52 AM
pistolpete17's Avatar
Originally Posted by Swiftoy,Mar 22 2009, 07:39 AM
I believe we are suppose to use a 90wt gear oil. 75/90 will suffice. no need to use the 75/110. If you want the heavy duty version use the Amsoil 75/90 severe gear oil and you will be fine.
Swiftoy
It was my understanding that SAE reclassified the weights. Doing so made the higher numbered gear oils the best suited for our diffs (not much higher). Making the current 90 weight lighter than the old 90 weight.
Again, just what I remember reading. Maybe someone in the know can jump in here.
Best to ask this on Bob the oil guy forum.
Old Mar 23, 2009 | 06:03 AM
starchland's Avatar
I just changed my fluids and went with Honda MTF - the revised version that has been out for a little bit. Apparently it contains new additives...and so far its working very well and im impressed. Shifting has improved and going into 1st there isnt any notchyness at all. Also, today its been quite cold (-5C) and the driving experience with the car cold has not changed any noticeable bit for me. So far, the new stuff feels great. I feel, that Honda must have spent quite a bit of R&D money on improving their fluid, so that gives me piece of mind!
Old Mar 23, 2009 | 06:20 AM
vtec9's Avatar
No reason to come within 100 meters of any GM tranny fluid with the new Honda MTF available.
Old Mar 23, 2009 | 07:24 AM
SquirtleS2K's Avatar
Dont forget the 24mm socket that you will need in the rear for the diff drain plug
Old Mar 24, 2009 | 10:39 AM
Good read here...
Old Mar 24, 2009 | 06:35 PM
s2guru's Avatar
Thanks a lot for the information, I'm doing my diff and tranny this weekend
Old Mar 24, 2009 | 07:31 PM
Artric's Avatar
And the 23mm for the other bolt. That's much more unlikely to have around.
Old Mar 24, 2009 | 11:59 PM
iam7head's Avatar
i beg to differ, new oem mtf is a very close second but gmsmfm still shift better esp when cold for me
<--almost 130k, zero grinds
