my ac is out! nooooo
Old 05-10-2005, 11:20 AM
BLOWNJROCK's Avatar
Default my ac is out! nooooo
well its like 90 degrees outside, and my armpits are sweating pretty bad.
i bought one of those freon kits, it said i had the right amount of freon so returned the kit. if i turn the ac on, the rpms raise plus that regular noise comes on, so i'm thinking that wasn't the case. air blows, but there is no COLD air. I took it up to a honda dealership yesterday to a friend, who is on here too. He was looking at my engine bay for a totally different problem and he looks at the fan on the driver side and see's the wire comming from it smushed by an intercooler pipe comming directly out the blower. he thinks that the wire was melted by the pipe blowing out the fuse.
so basically all i'm asking is I have to change out that fan right?
Old 05-10-2005, 11:44 AM
BLOWNJROCK's Avatar
anyone
Old 05-10-2005, 02:36 PM
jackhoff's Avatar
if the wire is completely cut, then connect it back together with some spare wire to see if thats the problem.
Old 05-10-2005, 03:34 PM
Slows2k's Avatar
You're going to have to fix the wiring 1st. The cooling fans need to operate for the AC to function correctly.
You may have more problems with the AC as well, whatever you do, DON'T use the "Add a can of freon" method of repair. you aren't fixing nything. You are making the problem worse by possibly contaminating the AC charge with air, risk mixing an incompatible oil in the refrigerant, or grossly overcharging the system.
You need to leave the AC work to an experienced liscensed technicain with the correct equiptment.
Valkyrie
04-09-2017 02:45 PM
Krisbuc
07-06-2014 11:09 AM
y0itzCARL
01-13-2010 02:37 PM
pikkashoe
10-16-2005 08:35 AM
Quick Reply: my ac is out! nooooo
