My Cold Start Engine Saga Continues
Old Nov 18, 2009 | 12:00 PM
  #21
nicholasbartleet's Avatar
I had the oil pan and chain cover off the car last week. It is absolutely immaculate. The pump pickup isn't blocked at all.
How would i check the pump? other than checking the pickup?
Old Nov 18, 2009 | 12:28 PM
  #22
iDomN8U's Avatar
using the oil pressure gauge
Old Nov 20, 2009 | 02:38 AM
  #23
I gapped the new ngk plugs to 0.043". Put them in. The car started beautifully first time. Work up the next day. Checked again and it started with no problems at all. I can't believe Denso would reccomend plugs that could cause such a problem in such a short space.
The only thing that seems odd is that my:
Short term fuel trim reads: -7% to -8%
Long term Fuel trim reads: -8.6%
Should i be getting negative (-) reading on my fuel trims?
Tickover is at 790RPM to 800RPM
Throttle position at idle reads 5.5% which seems odd. The TPS has been calibrated by me with a voltmeter.
Old Nov 20, 2009 | 04:02 AM
  #24
SpitfireS's Avatar
nicholasbartleet Posted: Nov 14 2009, 07:02 PM
I have found a piece of black silicone inside the vtec screen filter which must have made its way into the oil system when the shoddy mechanics put the front chain cover back on having changed the crank pulser for the engine swap.
Maybe smaller bits of silicone are (still) stuck in the timing chain tensioner?
Its close to the vtec valve.
That could explain the noise in that area.
You've checked just about everything else, IMO its worth it to check that as well.
The removal prodecure is in the manual.
You can take the TCT apart on a bench and put it back together.
As long as you are very carefull removing the small pressure valve, as it has 2 punches to lock it, that small valve is small enough to be blocked by debris though.
Or replace the whole TCT.
Might be expensive.
Or swap the TCT from your old engine?
Old Nov 20, 2009 | 04:33 AM
  #25
iDomN8U's Avatar
less fuel required since you're now burning at recommended spark gap
limenuke
Jun 27, 2017 03:27 PM
vansman
Feb 19, 2015 12:35 AM
Emil St-Hilaire
Oct 26, 2007 02:45 PM
alex.stanley
Jul 12, 2005 01:14 PM
Bassoctopus
Apr 20, 2005 10:38 PM
