My custom 4" exhaust
Old 03-20-2004, 02:47 PM
jahwerx's Avatar
Default My custom 4" exhaust
In my quest to stop breathing fumes while setting up the start/idle etc. of the EMS, I took a trip to the Home Despot and picked up about $30 in parts to vent the garage
It uses 2 butted 4" flanges that fit nicely in the 4" spugen exhaust tips (I used 4 1/2" hose clamps to seal the holes in the back part of the tip - I assume they are used to fit a silencer..)
Off of the flanges, flexible aluminum dryer vent connected to a heavy-duty plastic "Y" connector (with prodigious amounts of duct tape) and finally connected 2 8' sections drainage pipes that you can see in the second photo.
Took about 1/2 hour to put together.
The "Y" connector is easily strong enough to support my garage door, and I can always build a baffle for it if later on if I want to "fully" seal the garage . . .
Old 03-20-2004, 03:34 PM
ItalianBucwheat's Avatar
Very nice. Its amazing how even with the garage door open it only takes a minute or to to get gased out.
Old 03-21-2004, 09:29 AM
cjb80's Avatar
I can have your idle, cold startup, etc tuned in the time it took you to buy that tubing.
Chris
Old 03-22-2004, 05:08 AM
SKREEMR's Avatar
yeah, but you are in Florida and he is in NJ....
Old 03-22-2004, 05:21 AM
jahwerx's Avatar
True; when the temp is above ~45F, the car does start with the maps I have.
At colder temps, I have to do the ghetto trick; use OEM ECU, run for 20 seconds, pop the AEM back in and start her up.
Haven't had much time to play - next weekend I hope.
I saw a link on the AEM forums about injector timing - I may have gas pooling on the valves. I certainly have ENOUGH gas going in. Plugs look OK too (not wet or carbon fouled).
Old 03-22-2004, 06:30 AM
cjb80's Avatar
It's not going to be a mechanical problem if it works fine with the stock ECU... If the plugs look fine and you can't get it started, then obviously you don't have enough fuel. A wideband O2 sensor will solve the mistery. I do not recommend even driving the car with out a wideband. (Untuned)
Chris
jonybravo78
08-09-2011 09:30 AM
sspicollo8
04-09-2008 06:00 PM
9kFever
Socal Swap Meet
08-11-2005 06:16 AM
Ooalloems2koO
11-29-2004 06:25 PM
djkojione
08-03-2003 11:51 PM
Quick Reply: My custom 4" exhaust
