My S2000 is choking.. Helpp..!!
Originally posted by Mr_ITR
If this is a MAP sensor problem... who do I see to fix this??
If my car still have warranty... do you think Honda will fix it??
if its under warranty, then honda will definatley cover it. the map sensor is known to go bad on some s2000's. its only a $40 part and is very easy to remove/install. its the small plastic piece on top of the intake manifold with a blue honda sticker on it. it is held down by two screws.
read this thread: sounds like you have the same prob
http://forums.s2ki.com/forums/showthread.p...5&highlight=maf
Man i can't thanks you guys enough for trying to help me out...
This Forums is great.. many ppls have the Knowledge of S2000...
If you have any change to come to Australia... I'll show you guys around..
i'll check the link right now..
cheers
cheers
98 Octane....
Btw My problem is fixed.. Thanks RazorV3 and everyone that helped me to fixed this problme...
I took the Map Sensor out and give it a hit with and put it back it and works like< THE BEST EVER...
thanks again...
cheers
thanks again...
cheers
