My S2000 is pulling to the right. Hardcore.
Old Sep 15, 2004 | 06:06 PM
jestics's Avatar
Default My S2000 is pulling to the right. Hardcore.
When I got up this morning I noticed that on the backright pannel there were some yellow marks by my tires. Whether or not that means anything, I do not know so anyways:
I was driving along as usual and I realized that the car was veering to the right a considerable amount. If I were to let go of the wheel, I could change lanes (assuming of course I wanted to change to the right).
My first thought was of course, "Blast, I have to take it in for alignment" No biggie, but then when I started shifting, the car would wabble to the left and then the right. Same thing happened when I had my passenger shift while I had both hands on the wheel.
This happened several times and now I'm worried. Any ideas? I hope it just needs alignment but the wabbling makes me worry a bit more. Thanks for your help.
edit to add: Its not a flat tire, the tires are brand new.
Old Sep 15, 2004 | 06:57 PM
alexf20c's Avatar
Yellow marks on the body panels?
You got smacked in a parking lot.
Old Sep 15, 2004 | 07:03 PM
jestics's Avatar
That was my first thought, it just seemed to low to be a car hitting it...
Old Sep 15, 2004 | 07:11 PM
xviper's Avatar
Have you checked your tire pressures?
Old Sep 15, 2004 | 07:28 PM
jestics's Avatar
I have and everything was normal. Guess we'll see what the mechanic says tomorrow.
Old Sep 15, 2004 | 08:10 PM
Elistan's Avatar
Huh. If your tire pressures are okay, are you sure that the left and right rear tires are the same size? Nah - you would have noticed that on the drive home from getting new tires.
No offense, but did you actually use a tire pressure gauge? Or did you just visually inspect them?
Old Sep 16, 2004 | 08:14 AM
TubeDriver's Avatar
Even brand new tires can go flat. What was the yellow marks? Paint? Than you got hit by something.
Old Sep 16, 2004 | 08:28 AM
PrimoAP1's Avatar
Mine has a similar problem- I belive it is bump steer in my case.
I will be aligning again this mont h for the 100th time this year (Oregon has terrible pot holes and construction everywhere) and am going to buy a more accurate tire pressure guage tonight based on suggestions above. I think the badly abused guages at the gas station and the cheap onbe I got for free in the waiting room at the tire shop here are inaccurate.
Good luck with the wabble!
Old Sep 16, 2004 | 08:36 AM
RT's Avatar
RT
prime-ape what's up?
Old Sep 19, 2004 | 09:29 AM
Elistan's Avatar
jestics, what'd they say when you brought it in?
Andrew77
Apr 5, 2009 06:28 AM
TakmaN
Nov 21, 2008 08:45 AM
kartrcr4life
Sep 28, 2008 12:27 AM
norbtx
Dec 8, 2004 03:39 PM
MyEeek
Jul 7, 2003 11:19 AM
