MY03 TCT Problem? Video Inside
Old Apr 16, 2011 | 12:11 PM
SupremeGC's Avatar
Default MY03 TCT Problem? Video Inside
The car just started making this noise. There is no CEL, loss of power just this noise. Can someone confirm whether it is the vavles or TCT
http://www.youtube.com/watch?v=yjURlr0by5s
Old Apr 16, 2011 | 07:43 PM
SupremeGC's Avatar
I replaced the TCt and the noise is still there. It is still prominent gears 1-3/rpm 3k-up. I replaced it with OEM honda. I dont know if this is serious or not. Plz help
Old Apr 16, 2011 | 08:25 PM
TopGear's Avatar
That doesn't sound like valvetrain or TCT or valvetrain noise to me.. I'm not an expert by any means, but usually the TCT is more of a tick-tick-tick kind of noise. I'd describe yours as more of a thunk-thunk-thunk from the way it sounds in the video...
Hopefully somebody more knowledgeable can chime in. It's hard to tell over the computer, but if that thunking is as loud as it sounds in the video, I'd be hesitant to run the engine if I didn't absolutely have to. Sounds pretty serious to me.
Anyway, I know that wasn't too helpful, but maybe it'll get your thread a little more attention.
Old Apr 16, 2011 | 09:49 PM
SupremeGC's Avatar
possible rod knock?
Old Apr 17, 2011 | 12:35 AM
Carbon Blue's Avatar
im thinking rod knock, was it misshifted??
Old Apr 17, 2011 | 05:58 AM
SupremeGC's Avatar
Not at all, no abuse before it happened
Old Apr 17, 2011 | 10:09 AM
SupremeGC's Avatar
230 compression across the board
Old Apr 17, 2011 | 10:33 AM
SupremeGC's Avatar
I will add as well that IT ONLY MAKES THIS NOISE UNDER LOAD.
Wouldnt a rod knock be constant through idle or under load?
Old Apr 18, 2011 | 01:31 PM
durtbikedude365's Avatar
I'm thinking either rod knock or you possibly spun a rod bearing. Whatever the case is, I definitely would not drive it or even run it for very long at all. Did you run high RPM's when you were low on oil, over rev it, or anything like that?
Old Apr 18, 2011 | 02:58 PM
JEEBS's Avatar
I definitely sounds like rod knock. Listen to others and don't drive the car. It sounds pretty serious. I would hate to see further damage and have to replace the motor.
How is the oil level? AP1s are known to burn oil. Maybe that has some hand in it?
mrscbw
Apr 24, 2014 11:52 PM
s2kbtos
Nov 21, 2012 05:46 AM
AZ-S2000
Mar 24, 2012 03:52 PM
trainhead
Jan 16, 2010 08:02 AM
