Mystery Noise
So this noise starting probably five months ago after I installed my tein flex and anti bumspteer. It happens on the right rear and only in dry weather. It makes like a creeking noise and when I accelerate the noise accelerates also and when i slow down the sound slows down too. I changed that caliper because thought that was the problem but it wasn't. Anyone else had this problem? Any suggestions? Please help! Thanks
sorry. it's not a clicking its more like a creaking and it makes it at slow speeds and at high speeds and only on the rear right wheel. When i increase my speed the frequency of the sounds increases and when i slowed down my speed so does the frequency of the sound
I had this same problem check all your suspension bolts and make sure they are tight.
Check ALL of them on that side. Retighten them all if you have to until you find the loose one. It was loose bolt that made the noise. Only when you stop or take off.
