Mystery sensor
Old Oct 31, 2015 | 07:19 AM
Calzonii's Avatar
Default Mystery sensor
Can someone enlighten me as to what this sensor is above the oil filter and below the vtec solenoid valve?
If it helps its bolted into the crank case and it attaches to the same part of the loom as the 2 vtec sensors do. it is bolted to the loom with a verysmall 7mm bolt as shown in the attached picture.
I think it may be the engine oil pressure sensor? or possible the engine oil temperature sensor?
Thanks
Old Oct 31, 2015 | 07:30 AM
rossco's Avatar
Oil pressure switch. Makes oil light turn on if low oil pressure detected.
Old Oct 31, 2015 | 07:53 AM
Chuck S's Avatar
Oil pressure sensor. Needs a wire connected to it!
-- Chuck
Old Nov 1, 2015 | 02:07 AM
Calzonii's Avatar
Thanks guys!
Ap1s2kay
Apr 21, 2016 08:39 AM
boyguan
Apr 23, 2015 02:02 PM
08s2000CRbackinblack
Jan 30, 2014 08:45 AM
ROTFLMAO
Mar 19, 2010 06:57 AM
