need help!
Old Dec 30, 2008 | 09:14 PM
derko_06's Avatar
Default need help!
i have a 00 with about 75k on it, it is giving me codes for misfire in cylinder 1, 2, 3, AND 4 and every once in a wile it will start ticking! it has done this once befor but it all went away and the car has been fine for about a month. about 2 days ago it started up again and is runing like shit and has a realy rough idle! any ideas??
Old Dec 30, 2008 | 09:38 PM
negcamber's Avatar
Search on misfire in this forum or the "p" codes. But try the following one at a time till the misfire codes do not come back once they are cleared:
Replace plugs (OEM only)
Replace coil packs
Replace injectors
Old Dec 30, 2008 | 09:51 PM
derko_06's Avatar
i have replaced the plugs already and have cleaned the injectors. the coil packs are next on the list. but what about the ticking that it is making? if i get on the car it will go away sometimes but then other times it doesnt!?
Old Dec 30, 2008 | 10:39 PM
armthehomeless's Avatar
Did you over rev?
Do yourself a favor and don't drive it.
Old Dec 30, 2008 | 11:09 PM
derko_06's Avatar
no i have never over revd! the ticking almost sounds like its coming from the injectors but i cant tell for sure.
Old Dec 31, 2008 | 06:42 AM
negcamber's Avatar
The ticking may be unrelated. But do a compression test just to make sure you don't have a bent valve...since you are probably not the car's 1st owner, it may have been over revved previously and the valve has now dropped far enough to tap a piston head but not break.
Old Jan 1, 2009 | 07:25 PM
derko_06's Avatar
ok cool i will deff check that out thanks.
SMG1990
May 14, 2014 04:32 AM
silvery2ks2k
May 18, 2009 07:13 PM
DRE.
Oct 16, 2007 05:50 AM
AusS2000
Feb 15, 2007 08:00 PM
