need help cel again!!!!
Old Apr 13, 2003 | 04:50 PM
BlueS2000Boy's Avatar
Default need help cel again!!!!
i started a post a while back about how i had the spoon thermo with fan swtich and i was getting a cel with the thermo. i had it checked at my work with the obd2 sensor check. the person who sold me the thrmo sent me another one and i did a full coolent flush,fill and bleed when i changed it out again. and i still have the cel? could it be i just didn't bleed long enough? could there still be more air in the system? when i have the bleeder cap open how long does it usualy take for all the air to come out???
Old Apr 13, 2003 | 07:52 PM
xviper's Avatar
Not all of the air will come out of those two bleeders. It can take up to 3-4 driving cycles where you get the engine up to operating temps and then completely cooled down before you will "burp" all the air out of the system. Make sure you have your interior heater dial on HOT the whole time. After each cool down cycle, check your overflow tank and add more coolant. Continue to do this till you no longer need to add anymore.
Old Apr 14, 2003 | 08:59 AM
i am suppost to keep the air running with the compressor on correct?
Old Apr 14, 2003 | 09:37 AM
Gernby's Avatar
Former Sponsor
The A/C compressor doesn't need to be on, and the fan speed can be low. The important thing is that the coolant is flowing through the heater core. The coolant needs to get hot and cold a few times for it to "pump" all the air out through the coolant reservoir.
When I installed mine, I didn't do any bleeding. I just went for a few "spirited" drives and kept topping off the reservoir. I never got a CEL.
What diagnostic codes are you getting?
Old Apr 14, 2003 | 03:09 PM
i'm not 100%sure what the numbers said. but its coming up coolent thermostat
Old Apr 14, 2003 | 03:19 PM
xviper's Avatar
So does that mean the ECU thinks the engine is running too hot or too cold?
Old Apr 14, 2003 | 03:21 PM
not sure but it seems to get to 3 bars faster.
Old Apr 15, 2003 | 05:23 AM
Gernby's Avatar
Former Sponsor
Sounds like you either have a blockage or an air pocket. If everything was working properly, a colder thermostat will make it take longer to get to 3 bars. If it is cool out, you will even see the temp drop back down to 2 bars on occasion.
Old Apr 15, 2003 | 08:56 AM
i'm just going to try to bleed it a couple more times and hopfuly that will do it.
Old Apr 15, 2003 | 05:37 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
finding out the code # will greatly help us help you.
ll1l2l1l2lll
May 19, 2022 06:52 PM
project*stealth
May 6, 2013 08:36 PM
nightcrawler7188
Mar 4, 2009 08:25 PM
CwickStylz
Aug 31, 2006 11:46 AM
EriS2k
Feb 11, 2005 10:17 PM
