need help with eps relocation
Old Jan 26, 2010 | 05:08 PM
japhethwar's Avatar
Default need help with eps relocation
Today while starting my fusebox and eps box relocation I unplugged the eps box on my 06. I had the battery disconnected and I unbolted the box and removed the three connectors. I was basically just looking at the wiring and planning my approach. I ran short on time so I reconnected the eps box and reconnected the battery. When I started the car my eps light was on and the power steering was not functioning. I scanned the car with my snap on scanner and it showed no trouble codes. I double checked all connections and tried removing the battery cable and reconnecting the eps plugs. Nothing changes, does the eps need to be relearned or reset after being unplugged? Any help would be appreciated.
Old Jan 26, 2010 | 05:56 PM
Slows2k's Avatar
You flipped the 2 2 pin connectors on the EPS unit.
https://www.s2ki.com/forums/index.php?showt...&#entry17974009
I've yet to see a Snap-on scanner that supports EPS.
Old Jan 27, 2010 | 03:09 AM
japhethwar's Avatar
Thank you slows. You were correct my friend. I did not realize both connectors were the same. Thanks for the info.
Old Sep 10, 2010 | 12:39 AM
gogoevo's Avatar
i am having these issues after doing my wire tuck/eps relocation and i am sure that i did not switch the plugs.. i did extend a few power wires to the rack ect. can that cause any problems?
Old Jun 26, 2011 | 12:21 PM
Rob@ReidyRacing's Avatar
Bump! Need info also
Old Jun 27, 2011 | 04:53 AM
Slows2k's Avatar
You could switch them anyway just to make sure you didn't ?
Old Jun 27, 2011 | 02:35 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
OEM plug location as EPS unit sits in stock position:
connector with Black wire, white/red wire (rear of unit)
connector with Green wire, red wire (front of unit)
Old Jun 24, 2012 | 01:56 PM
S2KSean's Avatar
Sorry to bring this thread back but i was doing basically the same thing and when I hooked everything back up a few things i happened...
- Power steering doesn't work but, no EPS light. EPS doesn't even bulb check when key is turned on.
- Speedo works, but tach does not
- Vehicle idles extremely low when stopping at a stop sign/red light. Forgot I had the battery disconnected as well, idle has re-learned now.
I did de-pin the connectors but i drew out where they go on the connector and double checked them once in.
Perhaps if someone knows the pin-out for the connectors i could triple check, otherwise maybe this has happened to someone before.
lude92_si
Dec 15, 2017 07:16 AM
JoeyBalls
Apr 23, 2015 10:31 AM
nambiker
Mar 30, 2006 07:37 AM
rikhemi
Mar 24, 2006 04:54 PM
ideugene
May 22, 2004 06:34 AM
