Need Help on finding the hole to wire boost
Old Sep 28, 2004 | 06:52 AM
faukengenius's Avatar
Default Need Help on finding the hole to wire boost
hey guys so i've been having trouble finding the firewall hole that'll let me put the tube through the firewall of our cars. If anyone has any pictures that'll be great. But can anyone explan to me where it is located? I've mounting the science of speed pillar and need to find that specific location. thanks any help is greatly appreciated.
Old Sep 28, 2004 | 02:59 PM
xviper's Avatar
I don't have any pictures because each person does this in his own way. Here's mine:
If you look just below the brake fluid reservoir, on the firewall, you'll see a fairly large wiring bundle go through a big rubber grommet. I took a sharp, pointy knife and cut a small "x" in the grommet on one side and pushed the boost hose through it and into the driver's footwell. Make the "x" small and the rubber will close up around the hose, sealing it quite well. If you doubt that it seals, when you have finished, just glob some silicone seal aroung the hose.
Old Sep 28, 2004 | 03:15 PM
fperra's Avatar
There two grommets that I have used to route wires. Here is a picture of the easiest to get at. Just cut an x in it with a razor blade and push the wire through.
Old Sep 28, 2004 | 04:11 PM
jankemi's Avatar
Originally Posted by faukengenius,Sep 28 2004, 09:52 AM
i've been having trouble finding the .... hole...
Put some hair on it.
Old Sep 28, 2004 | 11:14 PM
thanks for the responses guys I think i'll take a stab at this tommorow morning.
Old Sep 29, 2004 | 07:49 AM
xviper's Avatar
Originally Posted by faukengenius,Sep 29 2004, 01:14 AM
take a stab at this
STAB .................................... Good one!
Old Sep 30, 2004 | 09:33 AM
95civicturbo's Avatar
You guys...
Old Sep 30, 2004 | 10:15 AM
thanks for the help guys and found it and i did stab it
s2kfreak69
Feb 22, 2015 06:34 AM
blueap2
Sep 9, 2010 03:21 PM
discus510
Oct 25, 2007 09:35 PM
amongmany
Mar 14, 2005 05:07 PM
