Need HELP! Idk what happen
Old Jan 29, 2013 | 10:13 PM
s2000maniac's Avatar
Damn u gotta check your oil at least every 2 days.
S2KIrishman's Avatar
Originally Posted by AWWHITE s2k
I changed my oil 2 week ago where the f@#k did it all go
if you have an AP1, you burnt it...let me guess, your car saw a lot of VTEC? im going to even go further out on a limb and say that when you changed your oil you used synthetic...am i right?
Old Jan 29, 2013 | 10:43 PM
AWWHITE s2k's Avatar
No I put high mileage 10w-30 in my car and as in high rpm u mean 5000rpms then yes
Old Jan 29, 2013 | 10:52 PM
2003AP1's Avatar
How many miles has it been since last oil change?
Did you check both sides of the dipstick when you added the new oil?
Old Jan 29, 2013 | 10:56 PM
2003AP1's Avatar
Originally Posted by s2kreeper
Hate to say it but everyone here is right. Engine noise is rod knock and that means new engine . AP1's are known to sip oil, especially under high rpm right(I think?) turns, when it typically produces white smoke. They really should make a service bulletin warning owners to check oil levels weekly or delete/plug their pcv valve.
If you plugged the pcv dont you think pressure would build up in the crankcase and start blowing out seals..(Oil pan gasket, valve cover etc)
Old Jan 29, 2013 | 11:43 PM
It's not blown white smoke not leaking no where no drips I'm just floored it ate all my oil in 2 weeks like really where the f@#k did it all go. I kno Honda burn oil but f@#k.-_-
Old Jan 29, 2013 | 11:53 PM
s2k-tilldeath's Avatar
DUDE! Sh*t man, I'm so sorry that happened to you. If you ever vtec you need to check oil asap since you have an ap1. I hope it's fixable without getting a new f20c
Old Jan 30, 2013 | 12:10 AM
Well ill find out tomarrow. I don't know shit about a f20c in rebuilding it maybe its time to find out or should I just try to find a low mileage f20c in see what I can sell in salavage on this motor?
Old Jan 30, 2013 | 09:18 AM
apme123's Avatar
What year is your car and what is the mileage How low was the oil? Did you check both sides of the dipstick, Also do you rev the motor past 6000rpm all the time? what kind of oil did you use? What Viscosity? How long have you had the car and what is its history?
Old Jan 30, 2013 | 01:52 PM
Carbon Blue's Avatar
how much oil did you add???
