need help pulling tranny
Old Feb 17, 2009 | 09:24 PM
  #21
Clark's Avatar
same here.
get the block & tranny 'cinched' back together and get that clutch fork out. When their close enough together, the fork should wiggle around loosely, you then just have to twist & wiggle it out.
Old Feb 18, 2009 | 06:40 PM
  #22
gomarlins3's Avatar
Originally Posted by derko_06,Feb 17 2009, 12:51 AM
what is the clutch fork? and were would it be?
Yikes.
Old Feb 18, 2009 | 09:45 PM
  #23
kharaal13k's Avatar
seems like no one is telling you exactly where the clutch fork is...it's what compresses the slave cylinder. all you need to do is unbolt your slave cylinder remove the plastic boot over it, and the fork is the only thing under it. all you have to do at that point is pull it outward. it will not come out of the transmission case it'll just hang there. it moves probably about a quarter of an inch to a half an inch.
Old Feb 19, 2009 | 01:42 AM
  #24
derko_06's Avatar
ok cool thank you.
Old Feb 19, 2009 | 06:32 AM
  #25
Clark's Avatar
You gotta get yourself a Helm's service manual if you're doing this level of work.
Old Feb 21, 2009 | 11:25 AM
  #26
derko_06's Avatar
got it off thanks for the help!
Old Feb 21, 2009 | 02:37 PM
  #27
Stratocaster's Avatar
OK, now tell us what the problem was. It may help us with the next guy needing help.
Old Feb 22, 2009 | 07:17 PM
  #28
derko_06's Avatar
it was the clutch fork. after takin that off it came out so easy, i was so pissed..lol
Old Feb 22, 2009 | 08:35 PM
  #29
Clark's Avatar
same thing here bro.... the thing that annoys me is the Helms manual isn't that clear on this either.
I spent days on this, don't feel bad.
Old Feb 22, 2009 | 09:19 PM
  #30
SR71BB's Avatar
Ok, I'm confused - Did you ever drop the subframe, or did you succeed with only removing the clutch fork?
