NEED HELP! Stoptech brake lines banjo bolt
Old Sep 25, 2005 | 09:39 AM
CaptKirk's Avatar
Default NEED HELP! Stoptech brake lines banjo bolt
Ok so I spent pretty much all of this weekend working on my brakes, and now when I was putting everything back together, one of the damn banjo bolts that came with the stoptech brake lines broke!! I was torquing it to the specified 25 lb-ft and the head just broke off!! Kinda worried me, but I was able to get the rest of the bolt out of the caliper.
My question now is: Can I use the banjo bolts off of the OEM brake lines safely?? I would REALLY appreciate it if someone could get back to me soon because I need to put my car back together ASAP!
Thanks in advance for any help...
Old Sep 26, 2005 | 10:18 AM
TubeDriver's Avatar
[QUOTE=BNavZ,Sep 25 2005, 01:39 PM] Ok so I spent pretty much all of this weekend working on my brakes, and now when I was putting everything back together, one of the damn banjo bolts that came with the stoptech brake lines broke!! I was torquing it to the specified 25 lb-ft and the head just broke off!!
Old Sep 26, 2005 | 10:20 AM
Ludedude's Avatar
Administrator
You can also contact Stoptech directly for a replacement. They'll get one to you ASAP.
Old Sep 26, 2005 | 10:34 AM
TubeDriver's Avatar
I should add that while I had no problems for ~15k miles using the OEM banjo bolts on Stoptech lines (with dozens of track and autoX events), I can't be sure that Stoptech has not revised their lines. So while I think it should be fine, it's your car, your brakes, and your life on the line.
Old Sep 26, 2005 | 10:53 AM
cdelena's Avatar
I also have found that aftermarket banjo bolts can fail easily.. just do not seem to be rated for much torque. I used the OEM bolts with other lines and have not had any problems in many years of use.
Old Sep 26, 2005 | 12:54 PM
jyeung528's Avatar
which bolts are we talking about...do you have pictures?
I noticed tha the bolt that attaches the ss brake line to a part...was loose and about to fall out...
Old Sep 26, 2005 | 05:19 PM
CaptKirk's Avatar
Yea yea the disclaimer
I get it...
and appreciate the input
Old Sep 26, 2005 | 05:20 PM
CaptKirk's Avatar
Yea the stoptech ones looked and just...felt like crap. The OEM ones looked much "tougher" and able to withstand more torque. I ended up just cleaning out the oem ones REALLy well and just reusing those...
Old Sep 26, 2005 | 05:21 PM
CaptKirk's Avatar
I'm talking about the hollow bolts with the holes that connect the brake line/hose to the brake caliper...
musicforthedeaf
Jun 6, 2015 02:47 AM
C3wrb
Apr 11, 2014 02:33 PM
Alex p
Apr 25, 2008 12:51 PM
Pantwone
Sep 29, 2007 09:31 AM
