Need help with stuck bolt on header heat shield....
Old Sep 11, 2011 | 02:24 PM
s2000maniac's Avatar
Default Need help with stuck bolt on header heat shield....
I'm trying to remove my stock header and I removed the two uper header heat shield bolts. When I tried to remove the last one in the middle it got a little loose and then it got tighter and tigher as I tried to open it. I'm confused, is it rusted? why is it getting tighter instead becoming loose? The bolt is circled in RED in the picture below. thanks for the help and suggestions.
Old Sep 11, 2011 | 03:06 PM
Sideways's Avatar
It will not come out. The heat shield is slotted so it can be removed without removing that bolt
Old Sep 11, 2011 | 03:19 PM
zeroptzero's Avatar
Not much you can do , you can try to spray some bolt lubricant but it won't get into the area you need, just keep loosening , it is rusted , it can break on you but you don't have many choices. Mine came out reasonably well.
Old Sep 11, 2011 | 03:20 PM
you are 100% sure?
Old Sep 11, 2011 | 04:10 PM
Finally got the damn thing off!!
What is this yelllow stuff on the motor mount?
Old Sep 11, 2011 | 04:20 PM
zeroptzero's Avatar
Can you feel it ?, some people have reported an orange fluid leaking out of the broken motor mounts, if it isn't an orange fluid then it might just be paint.
Old Sep 11, 2011 | 04:24 PM
yea I felt it, it looks like an orange powder
svencarlson07
Oct 28, 2010 11:51 AM
S2S
Oct 6, 2010 10:14 PM
TelosHedge
May 16, 2008 04:00 PM
00S2K01S4
Jun 6, 2006 09:42 AM
Nhan
Jul 31, 2005 04:38 PM
