need help with test pipe install
Old Jan 21, 2008 | 10:52 AM
  #21
MikeyCB's Avatar
Heat up that puppy with an aggressive drive, and then be extra careful touching the exhaust after. You might not need to acquire a torch if you do it that way. I'd be amazed if vice grips, penetrating lube and the heat from a drive don't help.
Old Jan 21, 2008 | 03:37 PM
  #22
HondaS's Avatar
i ended up cutting it off with a dremmal and installing new hard ware. but when i go to put the the cat back on im going to need to knock those other bolts out
edit:
the test pipe doesnt add any noticable sound with a stock exhaust to me.
Old Jan 21, 2008 | 05:55 PM
  #23
em18u's Avatar
really i thought it would make the stock exhaust more raspy
Old Jan 21, 2008 | 06:15 PM
  #24
J'sS2K's Avatar
Only if you cut off the resonator.
Jason
Old Jan 21, 2008 | 06:27 PM
  #25
em18u's Avatar
yea i dont have a resonator
Old Jan 21, 2008 | 08:08 PM
  #26
CKit's Avatar
Or if you're FI.
Old Jan 22, 2008 | 07:36 AM
  #27
superman6074's Avatar
i got a test pipe and an hks high power dual exhuast i love the way it sounds its got a resonator so at low rpm its not loud at all but wen u hit the gas it sounds amazing only problem is wen u first start up it idles high and has a very very low pitch loud rumble wich actually i dont mind much :-D
Old Jan 22, 2008 | 09:36 AM
  #28
HondaS's Avatar
ya its more raspy at wot but that's about it. I love the smell
Boostaholic
Aug 18, 2021 06:49 PM
ryanfeldman
Oct 18, 2009 02:19 PM
shotiable
Aug 6, 2008 06:40 PM
TookayS2K
Feb 19, 2008 08:17 PM
Munky1
Oct 4, 2005 08:03 AM
