Need some help guys!
I rencetly got my highflow cat taken out and replaced it with a 3 inch pipe still having both o2 sensors. When i got that done i put in new o2 sensors. when it came off the lift my car had a ruff idle and occasional idle surge. when i drove it, it sputtered for a bit then ran fine. I took it to autozone and pulled P0122 and P1457
Now everytime i drive it the first 2 minutes i drive it it sputters then drives fine and sometimes has a ruff idle
any suggestions?
any suggestions?
http://www.bigdaddiesgarage.com/straight-cel-fix.html
Try one of these matey, I have a cat replacement pipe on mine and you need to space your post-cat O2 sensor aways from the extra gasses and heat. It fools the ecu into thinking all is fine with your cat and therefore no CEL light
p0122 reads "catalys below efficiency level" on the snap-on scanner diagnostic machine so yeah CEL fix should definately sort that out. I put that link on because this guys are a little more expensive but he makes them out of stainless steel so no rust
Bruinlax
May 10, 2006 06:53 PM
