New '06 - Defective Diff
Old Nov 12, 2006 | 05:45 PM
kjgood's Avatar
Update: The new diff came in and was replaced by Smail Honda, Greensburg, PA on 11/8. The whines had actually been growing progressively louder up until this point, and the diff was really "singing away" the morning I dropped the car off. Smail swapped it out pretty quickly, and the new diff appears to be silent. I'll keep my fingers crossed with this one.
Old Nov 12, 2006 | 06:15 PM
FISH22's Avatar
thats great! how long did it take them to do the swap? keep us updated.
Old Nov 13, 2006 | 03:48 AM
RadioZero's Avatar
i wonder what diff fluid the dealer used in your new diff? or does a new diff come factory sealed with fluid?
also considering the '06 models have a beather box for the diff, i wonder if the beather box adds a little resonance chamber.
Old Nov 13, 2006 | 07:08 AM
mugenrsx's Avatar
Originally Posted by twohoos,Oct 26 2006, 11:39 AM
I've never heard of an OEM diff that DIDN'T produce gray, gunky fluid at the first change (even at just a few thousand miles). The service interval of 105K miles is pure fantasy. However, after the first change, they are typically fine (no more shavings).
Sounds like the OP is being taken care of, so why worry? For other new owners, keep in mind that this car's drivetrain is a symphony of whines, whistles, and rattles, all of which are normal considering its tight specs and the car's minimal sound insulation. (There should be no real vibrations, though.) I'd recommend a couple preventive fluid changes (see the many FAQs here for fluid choices and DIYs), then only start to worry if the sounds change or get noticeably worse, or if you pick up a vibration.
Oh, but shifters popping out of gear should be looked at. (Generally nothing serious, but you shouldn't have to live with it.) See FAQs and Service Bulletin areas for help.
I changed mine out at 9k and it came out pretty much clear, no gray gunk at all. It also didn't smell that bad unless I put my nose a few mm away from the fluid. I thought this was odd.
I don't really baby the car either. That fluid saw atleast 25 clutch dumps.
Old Nov 13, 2006 | 07:33 AM
mikegarrison's Avatar
Yeah, and if you take out what sound insulation there is, you'll really hear the diff. Since mine has lasted for 60K miles so far, I assume that whine I hear from it was always there, and I only started hearing it when I pulled out the interior trim and added a hard top.
11bangbang
Feb 21, 2016 10:27 AM
ChickenParm
Jul 13, 2011 08:03 PM
skaterboyroland
Feb 12, 2009 09:42 PM
Talstaff
May 6, 2007 12:34 AM
alfredo_mancho
Jan 7, 2004 05:22 PM
