Nitrous....
Old Jun 30, 2001 | 01:47 PM
YoungS2K's Avatar
Default Nitrous....
I recently thinking of putting a 75- shots of n2o in the S. This is for the purpose of ocassional encounters and montly drag strip. My knowlege on this n20 is limited. What are the safety concerns? I know that over usesage(ie-100shots or more on a stock motor) of n2o can pop ur engine in a snap. Any safety products available?
With the extra 75hp, can the stock fuel-pump provide enough fuel? Any other risk of running a fogger kit instead of direct-port beside uneven distributions? How many ways can you activate n2o.
Thanks in advance.
nick
p.s. any board member(s) currently running NOS beside Larry at Bodywerks?
Old Jun 30, 2001 | 08:13 PM
Eze8199's Avatar
i think you have to change some engine parts if you go over a 60 shot of nitrous in the s2k?
Old Jun 30, 2001 | 10:21 PM
TurboVtk's Avatar
All you have to do its get a 4 foger kit like i did, i run an 80 shot no problem, my kit its made by NX(nitrous express) and all the other parts can stay the same, since you will be running a wet system the nos will be mix with gas so you do not need any mods to the fuel system, in about a month and a half i will be running 8psi of boost and a 60 shot nos... Any more questions on nos dont hesitate to ask or pm! i must add if you will be running a nx system like i do the cost was 650 for the kit and 300 install, now i am getting a computer for it ( controller ) that will release nos progressibly by gears.. that is about 400 and 100 to install. you can have your nos set to go off by buttons or by wot ( having your foot all the way down on the gas)
Old Jun 30, 2001 | 10:34 PM
S2R's Avatar
S2R
That sounds like the way to go. It's not like you need power all the time. You only need it on special occasions.
omg_miiiike
Dec 7, 2009 05:33 AM
Tjs S2k
Jul 15, 2008 06:18 PM
sharptech
Dec 12, 2007 03:12 PM
s2khatch
Sep 23, 2003 05:48 PM
