No clutch pedal pressure after car sits
Old 10-31-2022, 07:20 PM
MoogieBoogie's Avatar
Default No clutch pedal pressure after car sits
My S2000 often sits for a few months without being driven. Lately, I found that the clutch pedal has no pressure. I have to pump the pedal a few times and eventually it builds up enough pressure to drive around. It's fine for a drive around town and then after I park it again for a few months, no clutch pedal pressure. Any idea what I should look into? Thanks!
Old 11-01-2022, 05:13 AM
B serious's Avatar
Received 1,277 Likes on 963 Posts
is there a fluid leak?
Old 11-01-2022, 06:44 AM
windhund116's Avatar
Received 1,451 Likes on 973 Posts
Also, could the fluid may need bleeding.
Old 11-01-2022, 07:39 AM
Thanks for the response. If there is no fluid leak around the master cylinder, is it safe to assume that there could be a leak around the slave cylinder? The fluid level doesn't seem low.
I had the Billman once over service done a few months ago so i assume the fluid was checked and replaced as well.
David meyrick
10-22-2022 01:41 PM
drewc
08-08-2015 01:07 PM
JDMQuip
05-15-2011 12:57 PM
jdmossdave
11-24-2004 01:41 PM
Drop Top
10-17-2001 08:17 AM
Quick Reply: No clutch pedal pressure after car sits
