no hot air
Old Jan 17, 2005 | 09:04 PM
Slows2k's Avatar
The Air Mix motor is what controls the H20 valve position. Try taking the cable off and moving it by hand to either position to see if you have hot air then.
Old Jan 17, 2005 | 09:07 PM
yogi's Avatar
It's on page 21-43 of my manual, might be a few pages off in yours, the title of the section is "Heater Valve Cable Adjustment". Have him turn the heat up in the car, you should see the cable open up the valve.
yogi's Avatar
You beat me to it slows
Old Jan 18, 2005 | 03:40 AM
fperra's Avatar
Check that the heater valve cable is connected and working. Here is a picture of the heater valve. Mine will be a little different than yours because I have rotated it 90 degrees.
Old Jan 18, 2005 | 06:14 AM
body80's Avatar
That valve is the one with the full range of motion. I've already tried taking off the cable and moving it by hand. Still nothing!!!!!!!!
What I haven't done is take it apart and see if it's really moving the valve inside the unit.
I know the heater isn't complicated. it just doesn't want to work for me.
Old Jan 18, 2005 | 03:13 PM
Slows2k's Avatar
Pull the outlet hose off the H20 valve and make sure the valve is open when you move the lever.
Old Jan 18, 2005 | 04:58 PM
xviper's Avatar
If that valve was not letting water in, wouldn't the water coming out be "warmish"?
Old Jan 18, 2005 | 05:16 PM
Slows2k's Avatar
If the valve was stuck closed, the outlet H20 hose It would be "kinda" or "quasi" warm, but not hot. I've seen the Lever's attachment to the ball valve on H20 valves break in the off position. The cable still move the lever, but the valve inside doesn't move.
S2KBlackout
Apr 9, 2016 10:08 AM
cdk456
Apr 29, 2014 10:20 AM
marcucci
Feb 7, 2011 07:33 PM
s2 kwicksilver
Jan 23, 2011 02:37 PM
s2kphil
May 12, 2010 05:50 PM
