Ap2 p0339 code
Hey guys i have a 05 s2000 and for some reason i have random p0339 code i already changed the crankshaft sensor with an new oem and it still does it any clues
Sent from my iPhone using Tapatalk
did some searching for ya. u said it started after it got cold down your way. maybe your battery is getting weak. I googled that code and it says sometimes a weak battery can cause this or a weak starter motor. heres the link http://engine-codes.com/p0339_honda.html
id be willing to bet if u change your battery and clear that code, it wont come back. its probably sensing a hard start and throwing that code. also check and make sure the ground on the back of the head is still tight and clean, that's where the crank sensor and all engine sensors/ecu circuit ground and wiring shielding/ecu logic grounds are all grounded at...
