noisy transmission
Old Nov 15, 2018 | 01:31 PM
Red 2000's Avatar
Default noisy transmission
my transmission suddenly has become noisy, sounds like internal problem but oil is clear........any ideas?
Old Nov 15, 2018 | 01:41 PM
cosmomiller's Avatar
Top Answer: 1
Oil? Do you mean you got underneath and checked the transmission fluid with your finger?
Old Nov 15, 2018 | 03:08 PM
Red 2000's Avatar
changed it, no leaks so it was full and fluid was clear with no indication of metal
Old Nov 16, 2018 | 10:48 AM
yourboysoap's Avatar
Throwout bearing? Mine completely came apart and would make grinding noises and be very rough when pressing in the clutch pedal. When I swapped trans/clutch, the ball bearings fell out of the trans case as it had come unsealed. You might need to isolate this issue a bit more. When does it make noise? Under load or in certain gears? When engaging/disengaging the clutch?
Old Nov 18, 2018 | 06:58 PM
Red 2000's Avatar
it makes the noise when clutch is engaged and accelerating, complete clutch replacement including throwout bearing less than 5K miles ago so think I can rule that out.....
Old Nov 18, 2018 | 09:44 PM
flanders's Avatar
Did you use OEM parts for replacement? Nachi throwout bearing and FCC disc/pp.
Old Nov 18, 2018 | 11:12 PM
riceball777's Avatar
Clutch buzz from aftermarket clutch disc maybe?
Old Nov 20, 2018 | 01:01 PM
Red 2000's Avatar
yes
Old Dec 11, 2019 | 07:11 PM
jaykays2k's Avatar
Did you find out what the issue was?
Old Dec 18, 2019 | 08:59 AM
LagunaPearlAP2's Avatar
I think a thorough description of the sounds being made would be good. So when clutch is engaged it makes a buzzing noise? Is it at all speeds and all gears? Is it in neutral as well? Changes with engine revs?
Carbon Blue
Sep 12, 2014 03:55 PM
bbak11010
May 25, 2009 05:19 PM
Touge Freak
Jan 23, 2009 06:55 PM
Eni
Jan 23, 2006 11:37 AM
Nevsky
Oct 21, 2005 07:46 PM
