not starting
Old Jul 9, 2014 | 09:38 AM
laymenterms's Avatar
Default not starting
Put key in push button. It 'half' turned over then stopped. Thought it was odd in 250k it has only not started once removed keys immobiliser button again JIC, key in push button, all lights on dash board flick off and on again with a click but no engine turnover. I have been doing a lot of short journeys (sub 5 miles) and the roof has been going up and down etc. So naturally I suspected battery. Tried jumping it but got the same click with no turn over. Anyone got any ideas?
Old Jul 9, 2014 | 09:55 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
If you battery is bad and your jumper cables are cheap, it will not crank. If your battery is good, let the car sit for 5 min with cables attached and doner car running. Then try it.
I still say dead battery. Go buy the heaviest cables you can find.
Old Jul 9, 2014 | 10:14 AM
Tried using 2 sets of jumpers connected at once to try and up the ampage, but will give the charging option a try. Thanks
Old Jul 9, 2014 | 05:20 PM
tbpom1003's Avatar
I had the same symptom when the battery was bad or very low. when the battery is good, the dash board doesn't flick off.
or make sure the connection of jump cable. last time I thought I clipped it in the right place (right above the battery terminal and connectors), but it wasn't. Try several place
dillonkennedy003
Dec 17, 2018 04:38 AM
msafountain
May 19, 2010 12:21 AM
ajv85483
Apr 29, 2010 11:30 AM
DamoK
Aug 23, 2007 04:19 AM
Chris888jj
Apr 25, 2005 10:11 AM
