occasionally weak/no crank when hot problem
Old Mar 11, 2017 | 12:28 PM
klemen123's Avatar
Originally Posted by S2K-OED
If you have a check engine light get the code(s) and let us know. I had a similar problem before when I first got the car. The code was P0325 . The suspects were a cam sensor and the crank sensor. The issue was the crank sensor.
no check engine light. i went to the mechanic and he checked for any code that could be in memory but there was none . I added another ground cable from negative battery terminal to chasis and cleand all relay and fuses and for now it still fires up imediately
Thanks for the tip did your car also cranck very slow because of the sensor?
Old Mar 11, 2017 | 04:15 PM
windhund116's Avatar
Originally Posted by HarryD
Haven't heard of that before, but the Amazon reviews shows it has quite the following.
I couldn't find any mention of this there, but is it really better than say the standby, cheap dielectric grease one might have laying around the garage?
Good stuff. Been using Deoxit products, for years... on hi-fi, guitars, and amps.
rikhemi
Jun 30, 2013 11:41 AM
S2Kevinn
Mar 6, 2012 06:01 PM
calvinnnnn
Jan 13, 2012 09:42 PM
kaissi
Oct 13, 2010 05:12 PM
howardtan
May 31, 2008 05:48 PM
