Odd Compression Test Results
Old Feb 20, 2019 | 04:35 AM
  #21
treimche's Avatar
Originally Posted by Billman250
The classic #4 cylinder liner failure will result in high compression in number 4.
Check the cylinder with a scope, with piston at BDC. Liner failure will look like a wide black stripe.
Do not pull the full pump fuse for a compression test. Fuel will still spray into the cylinders and skew the readings. It is also unhealthy for the engine.
Disconnect the injectors instead.
I will do a little searching, but do you have more info on this cylinder 4 liner failing?
Old Feb 20, 2019 | 05:03 AM
  #22
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Just bore scope it, it is easy to spot.
Old Feb 20, 2019 | 05:06 AM
  #23
Billman250's Avatar
Top Answer: 1
Originally Posted by fatjoe10
What's the mechanical/scientific reason behind having high compression with damage to the liner? interesting.
Liner damage allows excess oil to flood the compression rings, raising the compression.
Old Feb 20, 2019 | 05:54 AM
  #24
flanders's Avatar
Originally Posted by treimche
Let me explain a little better. With the leak down tester in cylinder 1, I can hear air escaping through cylinder 2 and 3 spark plug holes. It wasn't leaking through the spark plug hole where the tester was.
Thanks that makes perfect sense.
Old Feb 20, 2019 | 06:18 AM
  #25
treimche's Avatar
That makes sense. Any idea what causes this to happen? Something ring related that scores the cylinder liner?
Old Feb 20, 2019 | 07:48 AM
  #26
Deckoz's Avatar
40% leakdown? what the **** lol. my 220k motor has 6-8% across all 4 and all read 210psi with 5 cranks.
Something sounds wrong lol.
Old Feb 20, 2019 | 08:42 AM
  #27
treimche's Avatar
Yeah tell me about it. This really sucks. This is the pic I took of the gauges when checking cylinder #2. Maybe I did the math wrong.
Old Feb 20, 2019 | 12:07 PM
  #28
rpg51's Avatar
Do I understand correctly that the engine runs fine?
Old Feb 20, 2019 | 12:44 PM
  #29
BrewDay09's Avatar
Your results seem pretty high for an engine that actually runs. I notice you didn't have the cylinder head cover off during the leakdown test. How did you confirm each cylinder was at TDC during the test? Perhaps you had some valves that were not completely closed?
Old Feb 20, 2019 | 05:44 PM
  #30
treimche's Avatar
Yeah it runs just fine.
