Odd Compression Test Results
Old Mar 10, 2019 | 04:59 PM
  #71
treimche's Avatar
Bottom end is yet to be determined. I think if the bores are still round, I’ll get the head fixed up and put it back together. Run it this year and plan on a bottom end rebuild next winter.
Still trying to to figure out where to get these mysterious valve seats from.
Old Mar 10, 2019 | 05:25 PM
  #72
rpg51's Avatar
If it were me, I'd be looking for a good used engine.
Old Mar 10, 2019 | 05:47 PM
  #73
treimche's Avatar
Well those aren’t easy to find either.
Old Mar 10, 2019 | 08:41 PM
  #74
Deckoz's Avatar
Originally Posted by treimche
@Deckoz do you know where to purchase new valve seats from?
1. You are better off determining if you can lap the valves
2. Honda does not sell valve seats. These must be custom machined. You also will likely have to have an induction heater designed to remove valve seats, and nitrogen for install.
3. if your seats really are gone and cannot be lapped or reground without going out of service spec, you are better off getting a head. Unless you have the means to do #2.
Old Mar 28, 2019 | 04:35 PM
  #75
treimche's Avatar
Machine shop has made some good progress. New exhaust valve seats are in. All new valves/springs/retainers/locks/seals/guides are there so they can finish up everything and I'll reinstall the head.
Old Mar 28, 2019 | 04:48 PM
  #76
treimche's Avatar
Oh, also forgot to post up that I measured the cylinder bores and they are all within spec. The biggest variance of .03mm is only present in one cylinder (toward the bottom of the stroke), the rest are less than that, and some cylinders are still round according to my measurements. Crossing my fingers that the bottom end will hold up for a while still.
Old Mar 28, 2019 | 09:18 PM
  #77
s2000Junky's Avatar
Old Mar 29, 2019 | 03:29 AM
  #78
rpg51's Avatar
Good news. Hope this all works out, sounds like it may. Keep us posted!
Old Apr 10, 2019 | 08:17 AM
  #79
reallyangrydinosaur's Avatar
If you don't mind, how much was all of that head work?
Old Apr 10, 2019 | 10:20 AM
  #80
Deckoz's Avatar
Nice, did your machinist source compatible sized seats or machine them?
