OEM Hardtop latch screw spinning issue
If you get it removed and you need to replace the threaded insert ( pop nut , rivsert, threadsert, whatever they call them), then you need to drill out a wider hole that is the same diameter as the new threaded insert. The insert will have the same thread to accept the factory bolt if you buy it from Honda , it is listed in the parts diagram listing for the hardtop shell, or you can buy them in the aftermarket and you can order them to fit the oem bolt size. In the Honda hardtop parts menu the call the threaded insert a pop nut, you can see it in the online menu at majestichonda.com or any other Honda on line parts diagram.
I had the same issue on mine. I used a very small drill bit and drilled into the nut through the hardtop shell, about 1/4" away from the screw, then intentionally broke the drill bit in that hole so that stopped the nut from spinning freely. I then removed screw with a vice-grip.
Yes pretty much the same thing, the worst part is that you need to buy the installation tool, a bit expensive just to use one time unless you can find someone to lend you a tool. I used a home-made tool to install it on my hardtop and it worked fine.
home made tool? How did that work?
Since the rev nut tool is basically a bolt that threads into the insert, then pulls on it as you squeeze the handle to compress the insert into a sort of rivet, couldn't you just thread an actual bolt into the insert, and just keep tightening it until it 'rivets' the insert?
That would compress the rivet more slowly, but otherwise mimic what the tool does.
OP I pm'd you some pictures of my tool and inserts I used.
