OEM MAP sensor VS aftermarket
Hi guys.... is this MAP sensor better than OEM and if so, how?? Figured id ask the experts..
http://thmotorsports.com/i-404385.as...ingSeanVehSpec
Better in that it will read higher levels of pressure? Definitely. But unless your car is using Forced Induction (Turbo, supercharger, etc.) it really has no advantages for an NA car that I am aware of...
It appears that device is rated at 7bar, which is extremely overkill in my opinion though, even for a FI car.
The highest most FI people run is like 4bar. I think mine is 3bar and I definitely won't need more.
7bar = ~101psi
4bar = ~58psi
3bar = ~43.5psi
So yeah... like I said, most people won't ever need more than a sensor that reads that high. Guess it can't hurt much though.
7bar = ~101psi
4bar = ~58psi
3bar = ~43.5psi
It can hurt the car to go to high
The higher the sensor can read the lower the sensors resolution
The whole reading scale has to fit on 0-5v if it goes form -26" to 11psi (stock) you have great resolution
If it goes from -26" to 100psi it has CRAP resolution and .01v can mean a 3psi difference
Well.. i do plan to supercharge the car in the future so i figured id upgrade other things now so i dont have to worry about it later on. Im about to do the clutch but am gonna go after market ( not the bearings tho ) to make sure the clutch can handle a future supercharger so thats why i wanted to know if i should go with this MAP. Think ill go with the 4 bar for now...
If you put the sensor on now without an ecu upgrade to aem the car will not run on an OEM ecu
4 bar is overkill 2.5 would be the best of reading high enough and having good resolution
But what do I know I just make my own 2.5 using the Motorola 2.5bar sensor inserted into an OEM case
Hmmm, so you are saying if i replace the MAP get an OEM Acura RDX MAP in place of the OEM AP1 MAP?
neptuner
Mar 15, 2018 03:56 PM
