OEM style lip install problems
Old Mar 12, 2008 | 02:08 AM
TookayS2K's Avatar
Default OEM style lip install problems
I'm trying to install my front lip but I can't figure out exactly how... With the lip, I recieved 4 brackets and many little screws. I thought some how I could just bolt on the lip to the bumper when its off the car but it looks like I actually have to have it on the car. See below..
Also, I purchased some 3M double sided tape. Where do I apply this? There no area of this lip that is flat against the bumper (only edges).
Here is the bottom of the lip
bottom of my bumper
brackets and bolts I recieved
How I plan on installing the brackets... With this way I bolt the lip to the bumper using the bracket AND the screws going to the bottom of the car. Also this also makes a little gap between the bumper and the lip.. is this normal? Note, the lip HAS to be on the car when using the brackets like this.
Heres are the money shots. Don't mind the old couch, its in the basement.
Fitment is not TOO bad.
Old Mar 12, 2008 | 02:26 AM
xrapidx's Avatar
Can you do a before the lip is on and after its on the bumper, I'd love to see them side by side.
Old Mar 12, 2008 | 02:28 AM
TookayS2K's Avatar
There are plenty of pictures around with ap1s with and with out lips...
I'd love to get my lip on.
Old Mar 12, 2008 | 02:30 AM
xrapidx's Avatar
I can never tell which ones OEM and which one isnt...maybe cause I'm a noob
Old Mar 12, 2008 | 02:31 AM
Sz28r's Avatar
is this a OEM lip?? we recently installed an OEM AP1 lip on my sons car - - your brackets don't look the same - - and we didn't use any double sided tape on his.
My '05 AP2 OEM lip came with the double sided tape already in place.
anyhow - looks like you've got it installed - - good job
Old Mar 12, 2008 | 02:39 AM
TookayS2K's Avatar
Looks can be deceiving! It actually is just placed on there.. No bolts in what so ever.
Its not OEM, its OEM STYLE. Meaning that its a knock off.
Old Mar 12, 2008 | 04:18 AM
daktruckie99's Avatar
Yes the bumper has to be on the car when installing. Some of the bolts that hold the bumper on are covered up when the lip is installed.
In this picture:
See that hole on the left, with the OEM lip there are speed clips that slide in there and then the supplied bolts for the lip secure to that. There are about 5 of these under neath the lip and then 2 on each far end inside the wheel well. The ones in the fender are self tapping screws.
Your kit seems to have come with nuts and bolts and I can only guess that those brackets belong in between the nut and bolt in the same place the OEM speed clips belong.
Good luck.
Old Mar 12, 2008 | 05:23 AM
SIIK2NR's Avatar
The double sided tapes serves two purposes, to provide additional adhesive and to provide a small space between the lip and bumper. An OEM lip will have the double sided tape already adheased to the lip.
Old Mar 12, 2008 | 09:35 AM
TookayS2K's Avatar
[QUOTE=SIIK2NR,Mar 12 2008, 05:23 AM] The double sided tapes serves two purposes, to provide additional adhesive and to provide a small space between the lip and bumper.
getmadboy
Feb 16, 2021 02:52 AM
EYOS2000
Jan 8, 2019 09:02 AM
daniel3ooo
Sep 9, 2008 09:04 PM
tenblade2001
May 4, 2005 04:05 AM
tjohn
Jun 22, 2004 05:50 AM
